A quick question, John. What do you do for weldment profiles, i.e. tube frames? AFAIK there is no good way to miter the corners if each body is it's own part file... (???) Do you create a multi-body file for that part?Roasted By John wrote: ↑Mon Mar 22, 2021 9:01 amThat is why the SSP term is confusing, it isn't restricted to 2D sketches only, just for clarification to whoever would have an interest, the SSP can include Solids, Surfaces, 3D sketches etc..matt wrote: ↑Mon Mar 22, 2021 8:53 amI think I know what you're talking about. It's a 2D sketch that represents dimensions of parts of the assembly.Roasted By John wrote: ↑Mon Mar 22, 2021 8:17 am
I'm totally convinced that we are on a different page... The term SSP is a figure of speech that I put out quite a few years ago on the old Forum and it kind of stuck. It can be what @Frederick_Law implies as a "Master Sketch" or other people call it a "Master Part" it don't matter.
Let's say you have parts and the boundary between them is something you can't extrude. There are some products where you have to use a 3D construct instead of 2D. So the 2D sketch bit doesn't work for everything. That's all I'm saying.
Which Way To Go?
- x 1232
Re: Which Way To Go?
- Roasted By John
- x 268
- x 583
I don't use any of those features, primarily has to do with staying away from cutlists and bom related stuff, it might be a lot better today then what it was years ago. I know that people like to use weldments and multi-body designs, fine, being an old foagy, I prefer the regular modeling techniques, at the end of the day, "I Think" you are much further ahead, one workflow one system, parametric and robust. Don't forget.... I totally hope there is a better way, but if you think you found it, send me a model to test...mike miller wrote: ↑Mon Mar 22, 2021 9:03 amA quick question, John. What do you do for weldment profiles, i.e. tube frames? AFAIK there is no good way to miter the corners if each body is it's own part file... (???) Do you create a multi-body file for that part?Roasted By John wrote: ↑Mon Mar 22, 2021 9:01 amThat is why the SSP term is confusing, it isn't restricted to 2D sketches only, just for clarification to whoever would have an interest, the SSP can include Solids, Surfaces, 3D sketches etc..matt wrote: ↑Mon Mar 22, 2021 8:53 am
www.martinsroastapig.com
Pig Roast Your Way
Pig Roast Your Way
- x 1232
I'm dipping my toes into SSP. Not using weldment profiles seems very convoluted to me, even if all the other rules about multi-bodies apply.Roasted By John wrote: ↑Mon Mar 22, 2021 9:15 amI don't use any of those features, primarily has to do with staying away from cutlists and bom related stuff, it might be a lot better today then what it was years ago. I know that people like to use weldments and multi-body designs, fine, being an old foagy, I prefer the regular modeling techniques, at the end of the day, "I Think" you are much further ahead, one workflow one system, parametric and robust. Don't forget.... I totally hope there is a better way, but if you think you found it, send me a model to test...mike miller wrote: ↑Mon Mar 22, 2021 9:03 amA quick question, John. What do you do for weldment profiles, i.e. tube frames? AFAIK there is no good way to miter the corners if each body is it's own part file... (???) Do you create a multi-body file for that part?Roasted By John wrote: ↑Mon Mar 22, 2021 9:01 am
@mattpeneguy , do you use weldments?
- Roasted By John
- x 268
- x 583
The Technical Definition of Convoluted is
intricately folded, twisted, or coiled. (according to Google)..
You might find it hard to imagine I'm more inclined to be "intricately folder" rather then "twisted"
Here is one of my indicators..... Stay clear of most traffic issues, applies to questions/problems on the SW Forum, Weldments and Multibody features have had a lot of issues over the years. At any part of the day, week or month it seemed to me that there wasn't a day without people freaking out about those two features.. So I don't understand why someone would even consider using them, lol - help is close, don't jump..
Pig Roast Your Way
Pig Roast Your Way
- x 1232
Serious question, how would you model the attached part? I'd really like to know, because this is one of the last hurdles to cross before I start taking a serious look at SSP. Cheers, and thanks in advance.Roasted By John wrote: ↑Mon Mar 22, 2021 9:28 am The Technical Definition of Convoluted is
I go where there's work and money. Onshape and Inventor clients haven't been knocking down the door the way SolidWorks and NX clients have.
- x 1650
- x 2055
John,Roasted By John wrote: ↑Mon Mar 22, 2021 9:28 am The Technical Definition of Convoluted is
I mean no disrespect, but I can't imagine doing my job without multi-body Parts and weldments (and configurations, which I believe you also avoid). All three present very few problems if the user knows what he or she is doing (and getting to that point isn't difficult; I did it).
Glenn
- Roasted By John
- x 268
- x 583
Common saying around here "Whatever Floats Your Boat"
I just can't understand that if you get hurt, why go back for more... lol
Your turn -
Your turn -
Pig Roast Your Way
Pig Roast Your Way
- x 1549
- x 1402
That's what we are saying.
Master can be anything. Don't need to be sketch.
How does SE create 3D without "sketch"?
Or it just "hide" the sketch from user?
- x 1549
- x 1402
You've already done it.mike miller wrote: ↑Mon Mar 22, 2021 9:38 am
Weldment itself is a simple Master Sketch work flow.
Inventor Frame Gen is result of Master Sketch.
My "Weldment":
- x 1549
- x 1402
Weldment Master Sketch sample.
2021
2021
If all you are after are the same type of features that SW offers you don't need Mach bundles and could probably got with base (NX Sub. NX Core is around $3K per year)...or if you really want flexibility you can go with license "token" stuff. That allows you to use any software you want at a time based on your available tokens. It's pretty slick..
https://www.dex.siemens.com/plm/nx-clou ... lected=plm
Otherwise you can also look at Solid Edge subscriptions ($$2,700/yr for SE Classic which is comparitive to SW Prof)..don't forget to wheel and deal!
That's a ton of work....something like that I would have done using DriveWorks or a different CAD system, like NX, that allows for all sorts of design controls from a top level assy or pushing top level expression values down a product tree to using WAVE. NX has a ton of tools that come standard for "programming" your designs.Frederick_Law wrote: ↑Mon Mar 22, 2021 10:49 amYou've already done it.mike miller wrote: ↑Mon Mar 22, 2021 9:38 am
My "Weldment":
If mulit-body is needed then NX is the way to go. It could care less about how many solid bodies it has in it. I will say that if you want to use welds then I believe (70%) that you need to use an assy. But with NX you don't have a different file for an assy vs a part, vs sheet metal vs drawing. In NX a part is a part doesn't matter what it contains.Glenn Schroeder wrote: ↑Mon Mar 22, 2021 9:50 amJohn,Roasted By John wrote: ↑Mon Mar 22, 2021 9:28 am The Technical Definition of Convoluted is
Glenn
Is this just a tube frame? That's all I'm seeing.mike miller wrote: ↑Mon Mar 22, 2021 9:38 amSerious question, how would you model the attached part? I'd really like to know, because this is one of the last hurdles to cross before I start taking a serious look at SSP. Cheers, and thanks in advance.Roasted By John wrote: ↑Mon Mar 22, 2021 9:28 am The Technical Definition of Convoluted is
- x 1232
Yes. The "purist SSP guys" would never put more than one body into a part. Hence my question.Ry-guy wrote: ↑Mon Mar 22, 2021 3:29 pmIs this just a tube frame? That's all I'm seeing.mike miller wrote: ↑Mon Mar 22, 2021 9:38 amSerious question, how would you model the attached part? I'd really like to know, because this is one of the last hurdles to cross before I start taking a serious look at SSP. Cheers, and thanks in advance.Roasted By John wrote: ↑Mon Mar 22, 2021 9:28 am The Technical Definition of Convoluted is
On a tangent, how would SE deal with that?
- x 1650
- x 2055
Thank you. That may be valuable information for someone who is debating which software to use, but multi-body Parts in Solidworks work very well for me.Ry-guy wrote: ↑Mon Mar 22, 2021 3:24 pmIf mulit-body is needed then NX is the way to go. It could care less about how many solid bodies it has in it. I will say that if you want to use welds then I believe (70%) that you need to use an assy. But with NX you don't have a different file for an assy vs a part, vs sheet metal vs drawing. In NX a part is a part doesn't matter what it contains.Glenn Schroeder wrote: ↑Mon Mar 22, 2021 9:50 amJohn,Roasted By John wrote: ↑Mon Mar 22, 2021 9:28 am The Technical Definition of Convoluted is
Glenn
- x 1549
- x 1402
If I can get a proper BOM instead of F-Up cutlist, I'll use whatever.mike miller wrote: ↑Mon Mar 22, 2021 3:40 pm
One part, one drawing just easier to find everything.
