All
When a design table is first opened, SW2022 opens a window that offers a list of configurations and properties available to add to the table. After that first open, this window does not appear. Is there a way to get back to this window?
Thanks
how to reactivate Design Table query window on open
Well that window only appears when you edit the DT first time after creation OR you have "Show unselected items again" option selected.
To force it to appear again (in case you missed to select the "Show unselected items again" option), configure a feature/component in the feature tree (probably the last one) and change something to it like change the state and suppress it. After that edit the DT and window should appear. Now you can select the "Show unselected items again" option.
Go to full postTo force it to appear again (in case you missed to select the "Show unselected items again" option), configure a feature/component in the feature tree (probably the last one) and change something to it like change the state and suppress it. After that edit the DT and window should appear. Now you can select the "Show unselected items again" option.
Re: how to reactivate Design Table query window on open
Thanks, Deepak.
