Hey, gang.
I was reviewing the changes in the NX sketcher and saw them shake and break a sketch line away from the sketch. I can't recall if that was a function in the Solid Edge sketcher or not. I do recall this being an ability using the old (no defunct) Siemens App for tablets and phone- Catchbook.
Can you help me out? Is it in Solid Edge Sketcher?
Ryan
help remembering..
help remembering..
Google results say ST7 had shake and break sketching. I just tried in 2019 and it's not doing it. Thankfully though, I would not like that. Maybe it's a setting.
Go to full postRe: help remembering..
- x 2176
- x 1863
Sorry for sounding uninformed, but what is "Shake and break sketching"...?
It's kinda like "Detach Segment On Drag" but user doesn't need to remember to turn it off when done.AlexLachance wrote: ↑Tue Aug 29, 2023 4:48 pm Sorry for sounding uninformed, but what is "Shake and break sketching"...?
I prefer to just select the relations and delete which is why I hate that SW doesn't have coincident point sketch relation (it merges points and can only be broken apart with Detach). But I've found that I'm weird.
- x 1135
- x 1940
In SolidWorks......hold "control", grab line and drag,....let off control and drop line.bnemec wrote: ↑Tue Aug 29, 2023 5:07 pm It's kinda like "Detach Segment On Drag" but user doesn't need to remember to turn it off when done.
I'm an idiot. I copied the line three times before I came back and reread your post.jcapriotti wrote: ↑Tue Aug 29, 2023 6:09 pm In SolidWorks......hold "control", grab line and drag,....let off control and drop line.
Thanks for the verification! So it looks like the SE sketcher and NX sketcher are pretty much aligned. So those users that purchase a design bundle- a value meal of 1 NX seat and 2 SE seats- can move back and forth without much relearning/learning.
In Solid Edge, do the same but use the ALT key instead, and no need to remember to release the ALT key before dropping.jcapriotti wrote: ↑Tue Aug 29, 2023 6:09 pm In SolidWorks......hold "control", grab line and drag,....let off control and drop line.
