Save PDF to PDM
Library for macros
arild80
Save PDF to PDM
Unread post by arild80 »
Hi
I am realy bad at macro since i dont know VB.
I have a code that save PDF into folder in PDM (if folder is created)
I want to tweak this code a bit. To get the 8 first letters\numbers of the file name it looks into.
If fil name is named AB123456_01.assy i want to get 8 first didigts AB123456 as the folder name to look for, and the PDF name to be AB123455_01
The code we use is like this
Annyone who can edit the code for me ? :-)
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set Part = swApp.ActiveDoc
Dim sFileName As String
Set swModel = swApp.ActiveDoc
' Zoom To Fit
Part.ViewZoomtofit2
' Save As
sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
sFileName = Left(sFileName, InStrRev(sFileName, ".") - 1)
'sFileName = swModel.GetTitle
Debug.Print sFileName
longstatus = Part.SaveAs3("C:\Nordic Steel PDM\Varenummer\" + sFileName & "\" + sFileName + ".pdf", 0, 0)
by gupta9665 » Tue Jan 30, 2024 2:41 am
arild80 wrote: Tue Jan 30, 2024 2:21 am Would it be easy to do the same with STEP file?
Yes.
Change
sFileName = PDMPath + sFolderName & "\" + sFileName + ".PDF"
to
sFileName = PDMPath + sFolderName & "\" + sFileName + ".STEP"
and change
swModel.Extension.SaveAs3 sFileName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swExportPDFData, Nothing, nErrors, nWarnings
to
swModel.Extension.SaveAs3 sFileName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, Nothing, nErrors, nWarnings
gupta9665
Answers: 20
x 384
x 417
Re: Save PDF to PDM
Unread post by gupta9665 »
Try these codes.
Option Explicit
Dim swApp           As SldWorks.SldWorks
Dim swExportPDFData As SldWorks.ExportPdfData
Dim sFolderName     As String
Dim nErrors         As Long
Dim nWarnings       As Long
Const PDMPath       As String = "C:\Nordic Steel PDM\Varenummer\"
Sub Main()
  If swModel Is Nothing Then
    MsgBox "No active document.", vbExclamation
    Exit Sub
  End If
  sFolderName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
  sFolderName = Left(sFolderName, InStrRev(sFolderName, ".") - 1)
  sFolderName = Left(sFolderName, 8)
  swModel.ViewZoomtofit2
  Set swExportPDFData = swApp.GetExportFileData(1)
  swExportPDFData.SetSheets swExportData_ExportAllSheets, ""
  swExportPDFData.ViewPdfAfterSaving = False
arild80
Re: Save PDF to PDM
Love it Gupta. Thank you so much :-D
Answers: 13
x 2053
x 1712
Re: Save PDF to PDM
As another option, here is how I parse the filename and filepath.
'this is the full name and path
sModelPath = swModel.GetPathName
'get filename from full path
CropPos = InStrRev(sModelPath, "\")
sNewName = Right(sModelPath, (Len(sModelPath) - CropPos))
'strip sldprt extension
sNewName = Left(sNewName, Len(sNewName) - 7)
'get path
sNewPath = Left(sModelPath, CropPos - 1)
arild80
Re: Save PDF to PDM
gupta9665
Answers: 20
x 384
x 417
Re: Save PDF to PDM
Yes.
Change
to
and change
to
sloworks
x 5
x 17
Re: Save PDF to PDM
Unread post by sloworks »
Just an idea...you could also do a check-in for the exported files...PDM has quite nice support for VBA
BR
Markku
www.sloworks.fi
gupta9665
Answers: 20
x 384
x 417
Re: Save PDF to PDM
sloworks wrote: Thu Feb 22, 2024 11:18 am Just an idea...you could also do a check-in for the exported files...PDM has quite nice support for VBA
I'm trying to check-in an exported PDF file (which is saved locally into the vault) but it is not working. Can you please guide? Thank you.
Here are the codes I'm trying to use
Dim bRetval As Boolean
bRetval = model.Extension.SaveAs(OutputfileName, 0, 0, swExportPDFData, 0, 0)
Dim vault As New EdmVault5
vault.LoginAuto("VaultName", 0)
If vault.IsLoggedIn Then
	vault.RefreshFolder(outputfolderPath)
	Dim afile As IEdmFile5
	afile = vault.GetFileFromPath(OutputfileName)
	afile.UnlockFile(0, "", 0)
End If
The OutputfileName is the PDF file full name inside the vault folder. Also the PDF does not show up unless vault is refreshed manually. Using RefreshFolder doesn't work either. The aFile is always nothing,.
sloworks
x 5
x 17
Re: Save PDF to PDM
BR
Markku
www.sloworks.fi
gupta9665
Answers: 20
x 384
x 417
Re: Save PDF to PDM
Thank you for sharing the video, I have already checked and in the video the codes works OK because file is already there in the vault and visible. In my case, it show up only after refreshing manually. And I believe this is the reason that file is always nothing.
sloworks
x 5
x 17
Re: Save PDF to PDM
BR
Markku
www.sloworks.fi
gupta9665
Answers: 20
x 384
x 417
Re: Save PDF to PDM
Thank you I'll check these out.
CarrieIves
x 321
x 114
Re: Save PDF to PDM
Unread post by CarrieIves »
When we save a PDF into a PDM folder it automatically adds to the vault based on our settings in PDM for adding file types. We only have PDM Standard so can't do PDM macros, but our save as PDF SolidWorks macro, puts the PDF in the right folder. The setting adds it. We then just have to check it in.
gupta9665
Answers: 20
x 384
x 417
Re: Save PDF to PDM
CarrieIves wrote: Mon Feb 26, 2024 2:52 pm When we save a PDF into a PDM folder it automatically adds to the vault based on our settings in PDM for adding file types. We only have PDM Standard so can't do PDM macros, but our save as PDF SolidWorks macro, puts the PDF in the right folder. The setting adds it. We then just have to check it in.
Even for PDM professional, the add-in is putting the file in right location but PDF does not show until vault folder is refreshed. And adding the file to vault via API is not working.
sloworks
x 5
x 17
Re: Save PDF to PDM
BR
Markku
www.sloworks.fi
