Numbering an Array
MJuric
x 873
Numbering an Array
Unread post by MJuric »
So I have a grid pattern of holes. One direction is numbers 1,2,3 and so on depending on number of holes. The other direction is A, B, C etc depending on number of holes.
Is there a way to connect the array to the lettering in such a way that if the array pattern is changed that the numbering also updates? For instance if I have the array at 1,2,3 and A,B,C 3X3 and then change it to 4X4 the lettering will change to 1,2,3,4 and A, B, C, D? The lettering is in a sketch.
Austin Schukar
x 289
x 56
Re: Numbering an Array
Macro feature would be a neat way of tracking pattern instances and updating sketch numbering accordingly.
Austin
MJuric
x 873
Austin Schukar wrote: Wed Jun 23, 2021 2:57 pm Macro feature would be a neat way of tracking pattern instances and updating sketch numbering accordingly.
I've still not found a good solution to this but I suspect a macro would work. 1,2,3 etc works fine, A, B, C....no go.
Austin Schukar
x 289
x 56
Would you be able to elaborate on how you are getting the numbering sequence now?
Austin
MJuric
x 873
Austin Schukar wrote: Thu Jun 24, 2021 10:30 am Would you be able to elaborate on how you are getting the numbering sequence now?
Yep,
viewtopic.php?f=17&t=485&p=5723&hilit=ARRAY#p5723
Austin Schukar
x 289
x 56
MJuric wrote: Thu Jun 24, 2021 10:59 am Yep,
Very slick. Kudos to that creativity!
Austin
