New to the Forum
New to the Forum
Good Afternoon Everyone, Alex Here from the UK, Happy I found somewhere I can learn and ask questions about problems I'm having with my CAD software I hope to learn and grow. I will add a photo soon to my profile.
See you deep down in the comment section
Alex
Alex
- x 2191
- x 1891
Re: New to the Forum
Welcome to CADForum and the gang!
Hopefully you will learn, grow and eventually be able to even contribute to help others!
- x 1651
- x 2057
Welcome. What software do you use, and in what kind of industry?
I cant wait to be more involved.AlexLachance wrote: ↑Tue Jul 12, 2022 8:00 am Welcome to CADForum and the gang!
I'm using Solidworks 2020 (not by choice) and working in the agricultural machinery manufacturing industry (engineering)Glenn Schroeder wrote: ↑Tue Jul 12, 2022 8:29 am Welcome. What software do you use, and in what kind of industry?
What about yourself?
- x 1651
- x 2057
I've been using Solidworks since 2009, making models and then drawings used to build the stuff shown in the videos below.
You said not by choice. What part, Solidworks itself, or version 2020?
- x 1138
- x 1942
This just tells me that we need to put the cab in the rear of the truck.....yikes.Glenn Schroeder wrote: ↑Tue Jul 12, 2022 1:50 pm I've been using Solidworks since 2009, making models and then drawings used to build the stuff shown in the videos below.
- x 1651
- x 2057
Only if you plan to try to drive a truck into a secure area that's protected by one of those installations.jcapriotti wrote: ↑Tue Jul 12, 2022 2:53 pm This just tells me that we need to put the cab in the rear of the truck.....yikes.
By the way, I don't think the video has been posted, but we had a test years ago where the motor came up into the cab and went out the back window.
I want to know the specs on the u shaped pole. The truck hits it and self destructs, while it barely moves at all.
This is a "friend of a friend" story, so take it for what it is worth. I was told that he had a large transmission on a flat bed truck. Something happened in front of him and he couldn't get slowed down in time. What would have been a small fender bender turned into a fatality because the transmission wasn't properly secured and came through the cab.
Well, I don't hate solid works but it's my first CAD software, I've seen others like fusion360 and some others, not a big fan of the interface SW offers.Glenn Schroeder wrote: ↑Tue Jul 12, 2022 1:50 pm I've been using Solidworks since 2009, making models and then drawings used to build the stuff shown in the videos below.
I've used 3D software in the past like Autodesk 3Ds max that's how started my Digital 3D experience.
2020 was my first version so hoping 2022 is a little better but work doesn't want to upgrade just yet, if at all.
- x 2191
- x 1891
2022 seems to be a P.I.T.A. so far so you should wait a little longer and see the comments from further SP's.AllexDee wrote: ↑Wed Jul 13, 2022 5:10 am Well, I don't hate solid works but it's my first CAD software, I've seen others like fusion360 and some others, not a big fan of the interface SW offers.
Most likely wait until SP5, or SP5.1 if there's gonna be one(most likely)
What is it you don't like about 2020? Is there a specific feature that is giving you problems?
Something I've found hard but maybe it's just me not being proficient in the software yet is Mating, simple mates I find no problems but when mating to a curved surface it makes me punch the screen.
I'm sure there is more but cant think of any more from the top of my head.
- x 1651
- x 2057
I started to post a little information, and it would probably be okay, but I don't want to take a chance on getting fired.
Mating to a curved surface can definitely be challenging. Using sketches can help in some circumstances.AllexDee wrote: ↑Wed Jul 13, 2022 8:01 am Something I've found hard but maybe it's just me not being proficient in the software yet is Mating, simple mates I find no problems but when mating to a curved surface it makes me punch the screen.
From what little time I've spent in Fusion 360, it handles mating completely differently than SW.
- Ömür Tokman
- x 972
- x 328
Welcome Alex,AllexDee wrote: ↑Tue Jul 12, 2022 5:28 am Good Afternoon Everyone, Alex Here from the UK, Happy I found somewhere I can learn and ask questions about problems I'm having with my CAD software I hope to learn and grow. I will add a photo soon to my profile.
Alex
I think you will find what I am looking for.
And if I remember correctly @mike miller was in a similar industry.
This was a few years ago. Things might have changed, or my faulty memory may be at play.
Let's say you want to constrain this fastener to this panel.
In solidworks I would pick the face of the panel, and the underhead of the bolt and create a coincidence mate. Then I would select the cylinder of the hole and the cylinder of the bolt and create a concentric mate.
In F360 you would select the edge of the hole in the panel, and then the edge of the underhead of the bolt. The software would create both the face to face and concentric mates based on this selection.
(I had a bunch of screenshots in this post, but the forum and I weren't getting along, so I had to start over and didn't take the time to recreate them.)
That's quite neat! does SW support this function?SPerman wrote: ↑Wed Jul 13, 2022 10:13 am This was a few years ago. Things might have changed, or my faulty memory may be at play.
- x 1651
- x 2057
There are at least three ways to do something very similar in SW.SPerman wrote: ↑Wed Jul 13, 2022 10:13 am This was a few years ago. Things might have changed, or my faulty memory may be at play.
1. Set your bolt up with a Mate Reference. When you drag and drop it into an Assembly you can drop it so that concentric and coincident mates are applied (first screenshot). It takes a little practice to get the hang of it, but it works very well.
2. Grab the edge of the bolt, hold down Alt, and drag it close to the hole (second screenshot). Again, it takes a little practice, but you can drop it so that coincident and concentric mates are applied. It helps if you rotate the components so you can see both edges before first.
3. And then there's my favorite method. Ctrl+select the two edges and apply a Profile Center mate (third screenshot). You can also lock rotation on it, or leave it free to rotate. Of course you can also apply it with the Mate property manager open so you don't need to Ctrl+select them, but Quick Mates is one of those enhancements I resisted for a year or two, but now use often.
The 3rd method is exactly what I just discovered after commenting on your post, quite handy to be fair, will give the other 2 methods a try too.Glenn Schroeder wrote: ↑Wed Jul 13, 2022 10:32 am There are at least three ways to do something very similar in SW.
- Ömür Tokman
- x 972
- x 328
Hey Uncle this was a very quick start to teach.Glenn Schroeder wrote: ↑Wed Jul 13, 2022 10:32 am There are at least three ways to do something very similar in SW.
A classic texan, whoever's the fastest wins.
- x 2191
- x 1891
I honestly try and avoid Advanced Mates as much as possible. Not that they cause issues or anything, but they are named Advanced Mates for a reason, they tend to take more time for the program to calculate. If you end up having a huge assembly, it becomes somewhat noticeable.
- Ömür Tokman
- x 972
- x 328
Frankly, I had never noticed it.AlexLachance wrote: ↑Wed Jul 13, 2022 10:59 am I honestly try and avoid Advanced Mates as much as possible. Not that they cause issues or anything, but they are named Advanced Mates for a reason, they tend to take more time for the program to calculate. If you end up having a huge assembly, it becomes somewhat noticeable.
and
I don't prefer drag-and-drop mate because mostly the bolts are associated in the opposite position.
- x 1138
- x 1942
We use "Symmetric" and "Width" mates a lot. Kind of hate that they are under "Advanced", I view them as normal mate options.AlexLachance wrote: ↑Wed Jul 13, 2022 10:59 am I honestly try and avoid Advanced Mates as much as possible. Not that they cause issues or anything, but they are named Advanced Mates for a reason, they tend to take more time for the program to calculate. If you end up having a huge assembly, it becomes somewhat noticeable.
- x 1651
- x 2057
I had the same problem with a few of my models. It turned out that when I (or whoever) modeled them the head and shaft were two bodies. When I combined them into a single body that problem went away.Ömür Tokman wrote: ↑Wed Jul 13, 2022 11:08 am Frankly, I had never noticed it.
and
- x 2191
- x 1891
Those are the 2 we use most too, but we try to avoid them when possible. As stated, the difference isn't really noticeable unless you end up with multi-level large assemblies that have a lot of these.jcapriotti wrote: ↑Wed Jul 13, 2022 3:19 pm We use "Symmetric" and "Width" mates a lot. Kind of hate that they are under "Advanced", I view them as normal mate options.
- x 2191
- x 1891
It has to do with what SolidWorks conciders as the direction of the plane/model. I think I remember someone explaining that you could switch the direction with custom made planes, but I don't think you can change the direction on the 3 original planes.Glenn Schroeder wrote: ↑Wed Jul 13, 2022 3:52 pm I had the same problem with a few of my models. It turned out that when I (or whoever) modeled them the head and shaft were two bodies. When I combined them into a single body that problem went away.
- Ömür Tokman
- x 972
- x 328
I usually draw the bolts, screws etc, with the revolve command and it is a single body, the mate is 90% inverted. but tomorrow I will examine what you said, maybe there is an error I missed. Thank you for this information, Uncle.Glenn Schroeder wrote: ↑Wed Jul 13, 2022 3:52 pm I had the same problem with a few of my models. It turned out that when I (or whoever) modeled them the head and shaft were two bodies. When I combined them into a single body that problem went away.
- x 1651
- x 2057
If you don't find anything, attach a Part here and maybe someone can figure it out.Ömür Tokman wrote: ↑Wed Jul 13, 2022 4:39 pm I usually draw the bolts, screws etc, with the revolve command and it is a single body, the mate is 90% inverted. but tomorrow I will examine what you said, maybe there is an error I missed. Thank you for this information, Uncle.
Maybe. But always keep an eye on those who play "The long Game".Ömür Tokman wrote: ↑Wed Jul 13, 2022 10:47 am Hey Uncle this was a very quick start to teach.
