Convert Spline to Arcs Macro
step2design
Unread post by step2design »
Hi all,
I've given the forum a good seraching and can't find what I'm looking for so am hoping that someone can help.
I'm after a Macro that was attached to the Solidworks forum thread ->
https://forum.solidworks.com/thread/221366
It was either called aaaReArcs.swp or aaReArcs.swp
Or maybe Spline to Arc.swp
I'm not entirely sure, but it was an absolute life saver and due to a computer crash I've lost my local copy and in desperate need of another.
Does anyone have it in their Macro library?
Thanks in advance,
Sam
JPARKER
x 8
Re: Convert Spline to Arcs Macro
Unread post by JPARKER »
Here is the one I have.
splines2arcs.swp
(265.96 KiB) Downloaded 571 times
step2design
This seems to have done the trick.
Thanks - you are a lifesaver!
Farouk
Unread post by Farouk »
HI @JPARKER
I run SolidWorks 2023
I downloaded the macro but I have a mistake that says I can’t execute it.
can you help me ?
Thank you
Arthur NY
x 34
x 166
Unread post by Arthur NY »
Maybe some context might help us to better understand what you're looking to do. As that could net, depending on the Spline, anywhere from 3 - 3000 curves...or more. I'm exaggerating but you get the point. If it's for simply adding measurements I'd ask why. That there's functionality that actually works better in the inverse meaning drawing the arcs out then tracing one Spline over it. These are just shots in the dark so any additional info would be helpful.
Farouk
hi @Arthur NY
I tried to illustrate the steps of my work on this photo to better understand example of 3D scenery ( same for a 2D decoration as sent previously)
The mechanical-welded cladding is the selection of arches and lines of sketches,
The choice of the profile that will be bent to the desired shape to achieve the decoration is chosen according to several criteria
Sometimes I make sketches for each profile that will be used and other times I make sketches that may have several different profiles.
I have to select segment by segment (arc or line) when I am on the function "mechanical-welded element"
https://zupimages.net/viewer.php?id=23/08/q68y.png
x 2157
x 1847
Farouk wrote: Wed Feb 22, 2023 3:09 am HI @JPARKER
can you help me ?
Thank you
Go edit your macro
Go in Tools>Edit>Reference
Check the boses for these but in 2023
Farouk
Hi @AlexLachance
I can't open or edit the macro
Here App done by @ m.blt on this forum big thanks to him
https://forum.lynkoa.com/t/macro-api-ch ... /108806/17
x 2157
x 1847
Farouk wrote: Fri Feb 24, 2023 3:31 am Hi @AlexLachance
I do not have 2023, I cannot do it for you.
