CutList Macro
Library for macros
wdoguin4
CutList Macro
Unread post by wdoguin4 »
Hello all,
I've got a macro I'm trying to modify to pull exactly what I need. What I'm looking for is when I run the macro, for my weldment Mk# to come from "Part Mk#" in File Properties and then be ordered sequentially. Right now when I run the macro the Mk# is coming from the file name.
This is the macro I'm using. I'm thinking the - Name = swModel.GetPathName is what I need to change, but I'm not sure what I need to insert to pull from file properties and not file name.
Thanks for any help. I've got just enough knowledge on this stuff to mess things up!
Option Explicit
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim strValue0 As String
Dim strValue1 As String
Dim strValue2 As String
Dim bool As Boolean
Dim Name As String
Dim z, x As Integer
Dim boolstatus As Boolean
On Error Resume Next
Set swModel = swApp.ActiveDoc
Name = Dir(Name)
Name = Left(Name, Len(Name) - 7)
If Right(Name, 2) = "00" Then
Name = Left(Name, Len(Name) - 2)
Else: Name = Name & ""
Set swFeat = swModel.FirstFeature
z = 1
x = 0
Do While Not swFeat Is Nothing
If swFeat.GetTypeName() = "CutListFolder" Then
x = x + 1
Loop
If x > 1 Then
Set swCustPropMgr = swFeat.CustomPropertyManager
If z < 10 Then
swCustPropMgr.Add3 "Mk#", 30, Name & "" & z, 1
ElseIf z >= 10 Then
swCustPropMgr.Add3 "Mk#", 30, Name & z, 1
'for metalsheet
If UCase(swFeat.Name) Like "*SHEET*" Then
swCustPropMgr.Add3 "Mk#", 30, "Plate", 1
z = z + 1
Loop
boolstatus = swModel.ForceRebuild3(True)
x 599
Re: CutList Macro
The MK# is assigned with name value is because of the following code:
If z < 10 Then
ElseIf z >= 10 Then
http://help.solidworks.com/2014/english ... ~add3.html
You could use CustomInfo or Get5 to get the Part MK# in your custom properties and assign it to your MK#
EG:
Dim PartMKNo As String
PartMKNo = swModel.CustomInfo("Part Mk#")
If z < 10 Then
swCustPropMgr.Add3 "Mk#", 30, PartMKNo & "" & z, 1
ElseIf z >= 10 Then
swCustPropMgr.Add3 "Mk#", 30, PartMKNo & z, 1
wdoguin4
Re: CutList Macro
Zhen, thank you!
I'm having a difficult time trying to determine where to put the "PartMKNo = swModel.CustomInfo("Part Mk#")" line. When I add it under the "Dim PartMKNo As String" I get an Invalid outside procedure error.
When I add it anywhere else I get a Name not defined error.
Sorry to be a bother, but thank you for your help!
