Using Document Manager API from Excel
gerard
x 6
x 35
Unread post by gerard »
So,
I've got a Document Manager Key, and have created a vba macro in SolidWorks which verifies all is fine and good in Document Manager land.
So, I want to do some custom property stuff from within Excel, so I look at this wonderful source https://www.codestack.net/solidworks-do ... functions/
I've got basically the exact same code to connect to Document Manager that works under SolidWorks. All the same references are checked, yadda, yadda, yadda.
But when it gets to Set swDMClassFactory = CreateObject("SwDocumentMGR.SwDMClassFactory")
VBA burps and says"
Run Time error '-2147221164 (80040154)':
Class not registered.
Yes I have the SwDocumentMgr 2022 Type Library selected in references.
Any idea why this is spitting at me?
Could this be a 32 bit vs 64 bit thing? Unfortunately we are running the 32 bit version of Excel 2016.
Thanks,
Answers: 24
x 243
x 396
Re: Using Document Manager API from Excel
gerard wrote: Thu Feb 16, 2023 8:47 am
This is almost certainly the issue. It's a similar error I get when I forget to un-check "Prefer 32-bit" when I use Document Manager in Visual Studio.
gerard
x 6
x 35
AlexB wrote: Thu Feb 16, 2023 9:38 am This is almost certainly the issue. It's a similar error I get when I forget to un-check "Prefer 32-bit" when I use Document Manager in Visual Studio.
Thanks.
Yea, a bit of digging indicates that the dll is 64 bit. There do seem to be some ways around it, but I'll have to get my IT folks involved.
cheers
gerard
x 6
x 35
So,
I flipped it around and wrote the thing in the Swx IDE. Writing to an excel file is easy.
It's trudging away as we speak....
gerard
x 6
x 35
Ok.
Thanks so far.
The macro works fine.......
But it's slow, and as it trudges through folders gets slower.
Currently I use GetPreviewBitmap to create an stdole.stdpicture object
Then use stdole.savePicture to save a physical image on the drive.
Then use sheet.shape.addpicture to inset the image into a cell.
Is there anyway to insert the stdole.stdpicture object directly into a cell?
I've looked around and haven't found anything helpful, but I suspect I really don't know what to look for.
Thanks in advance.
gerard
x 6
x 35
More "goodness".
The tool works fine, but....
I'm running it multiple times to select folders to write these "catalog" files in.
Every other time I run the thing Excel opens with a new file and then burps with "run-time error 1004 Method "ThisWorkbook' of object '_Global' failed" when I try to write anything to the sheet.
Simply killing the macro, and closing excel and then restarting the macro, it runs just fine.
Any ideas why?
Thanks,
Answers: 54
x 7
x 820
Post your code that is interacting with Excel. Without it, we'll be guessing.
gerard
x 6
x 35
Ok,
I use a subroutine to do all the setup before writing.
sub template_setup(xlApp as Excel.Application, xlBook as Excel.Workbook, xlSheet as Excel.Worksheet)
set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
Set xlBook = xlApp.Workbooks.Add
Set xlSheet = xlBook.ActiveSheet
xlSheet.Columns("A:A").Select
Selection.ColumnWidth = 25 ====> This is where it burps, every other time the routine runs.
end sub
In my main routine:
sub main()
'at the end of execution
xlApp.DisplayAlerts = False
xlBook.SaveAs (strxlfilename)
xlBook.Close
xlApp.DisplayAlerts = True
' and then finally:
set xlBook = Nothing
set xlSheet = Nothing
set xlapp = Nothing
end sub
The odd part of all this is there is a dialog box for the user to select file types to catalog (it uses radio buttons).
The first time the routine runs, none of the radio buttons are select. The second time, the radio button selected last time is selected. If this is the case then the Excel part of this will burp. I've tried forcibly resetting the form, but that doesn't need to help.
How does one go about COMPLETELY resetting everything after a VBA macro is done? I've set all the various objects to Nothing, but it doesn't seem to help.
G
Answers: 54
x 7
x 820
gerard wrote: Mon Mar 13, 2023 1:08 pm Ok,
It's a little strange to pass these three objects to the subroutine and then initialize them. Why not simply Dim the three variables in your module and then just initialize them in the setup routine?
Dim xlApp as Excel.Application
Dim xlBook as Workbook
Dim xlSheet as Worksheet
   template_setup
End sub
Sub template_setup()
  Set xlApp = CreateObject("Excel.Application")
xlBook.Close
' and then finally:
set xlapp = Nothing
end sub
You did everything except tell Excel to actually stop. Add a call to
xlApp.Quit
gerard
x 6
x 35
JSculley wrote: Mon Mar 13, 2023 3:56 pm It's a little strange to pass these three objects to the subroutine and then initialize them. Why not simply Dim the three variables in your module and then just initialize them in the setup routine?
xlApp.Quit
That makes sense.
I had the initialization in the main sub, but moved it here to attempt to isolate the issue.
I'll add the stop code.
thank you
gerard
x 6
x 35
Sigh. No change.
I refactored the set up routine, so instead of:
Its:
xlSheet.Columns("A:A").ColumnWidth = 25 ===> Which is where it purps.
Some innerweb spelunking hints that it is a duplicate worksheet hiding somewhere.
When it burps, there is an Excel Background Process running.
If I directly close Excel (with the "X"), it closes the background process and then the macro will run successfully.
If I end the background process from Task Manager, Excel burps with an automation error.
How do I end the background process from the macro.
cheers,
G
Answers: 54
x 7
x 820
Can you upload your entire macro?
gerard
x 6
x 35
Unfortunately, no. Protected enclave.
More digging indicates that a linkage to an add-in com object is happening, which remains active after killing Excel in VBA.
Microsoft's solution is not just to de-activate the COM add-in, but completely remove it.
https://learn.microsoft.com/en-us/offic ... es-running
Of course this requires admin privilege's that I don't have as the add-in's are done on a group level. Again, protected enclave...
Sigh.
Thanks for the help. I'm just going to have to call this an unsolvable problem.
Answers: 54
x 7
x 820
Rather than closing Excel each time, perhaps you can use GetObject first (to attach to an existing Excel instance if it exists) and if it fails, then call CreateObject. See this link for details.
gerard
x 6
x 35
Yay!
The answer: https://support.microsoft.com/en-us/top ... 815d47702d
All my references were changed to specifically call out the sheet object:
e.g.
column("A2")
became
xlsheet.column("A2")
:cry:
This is a function of the fact that it's all being done from the SolidWorks VBA tool vice the excel VBA tool. In Excel it wouldn't have mattered.
Thanks,
G
