SW2022SP5
The other day I was playing with my test PC resettIng the registry to default and switching back and forth to our company settings and somehow when creating a new file from the file menu I got a template dialog with 3 templates named "empty" (or probably "blank" as I am not localized in english I cannot say for sure what is the correct translation in SW)
well it seems that SW had no templates at that moment and the new part file that came out was strange...e.g. I was not able to insert a sensor and the command returned no error at all.
I reproduced it a couple of times and the file properties (first tab in the custom property dialog) shown the file format as "solidworks 95 beta"
Instead of creating a new file from the file-new menu, I selected the part icon from the welcome screen and I was able to insert a sensor a usual. file properties identified the file as "solidworks 2022" as it should be. at that point the correct empty templates where apparently created in disk (default location C:\Program Data\Solidworks... )
solidworks 95beta??
- x 176
- x 214
Re: solidworks 95beta??
Nice to see these old formats appear.
- x 1538
- x 1381
So they never bother updating the internal default template.
Or do they still have the source code to update that?
In the bad files, right click one of the default planes and select 'Feature Properties'. What dates are listed there for created and modified?mp3-250 wrote: ↑Tue Apr 11, 2023 5:00 pm SW2022SP5
@JSculley It was the first thing I looked at that when I saw the bad file. unfortunately the date was the creation date aka 2023... scary as hell!
@Frank_Oostendorp that's it!
were you able to reproduce it?
strangely the new file from the welcome screen gave correct 2022 empty files.
- x 176
- x 214
Yes, if SolidWorks can't find templates, it creates or finds one, showing the 95 Beta property. So somewhere, this data is present, after almost 30 years.
- x 176
- x 214
The file structure has become a mess. In stead of updating, they just added new files on other locations, leaving the old ones. And on top of that, some equal data is present on up to 6 locations. In my job a no-go. There is only one set of data, that can be called for by multiple routines of multiple processors. Always wondered why the amount of installed data has become huge.Frederick_Law wrote: ↑Wed Apr 12, 2023 1:56 pm So they never bother updating the internal default template.
