Remove Document Number/Revision Number:-Title
Ronan1961
x 8
x 6
Unread post by Ronan1961 »
I installed Community edition 2023 recently and imported about 60 parts from SW. The data manager was active. I have disabled it but all open parts list as eg Document Number/Revision Number:-Title:5(File name.psm) .
I just want the file name to show on the open tabs and in the assembly tree. grumph
KennyG
x 43
x 178
Re: Remove Document Number/Revision Number:-Title
Unread post by KennyG »
Ronan1961 wrote: Thu Apr 20, 2023 7:35 pm image.png
That is controlled by the Options. (So.. File, Settings, Options) and on the Helpers page near the bottom you are looking for "Document Name Formula". Set it to: [Filename]
That is the default, so not sure how it got changed.
Ronan1961
x 8
x 6
Thank you. It probable got changed because I activates the data manager on install/setup.
