I created a simple hole on a face of a block. I then created a dimension from an edge of the face to the center of the simple hole.
But the dimensions does not show in the Equation Manager.
Is this normal behavior? I am not a regular user of SolidWorks, so am I missing something?
Also, do you use simple hole feature or you just use Hole Wizard to create even a simple hole? Just curious to know!
Thanks in advance for your responses.
- NirVidP
Simple Hole sketch dimensions in Equation Manager
- x 1
- x 1158
- x 1957
Re: Simple Hole sketch dimensions in Equation Manager
I use Hole Wizard for typical standard size holes, mostly for fastening hardware. And cut extrude holes for everything else. I never use the simple hole...seems like there were limitations at one time...maybe no longer though.
