Getting Path Centerline from imported surface
x 599
Is there a way to get the path centerline from an imported surface below?
(It was known that the surface should have a constant diameter and the path is a spline)
Step and parasolid file attached
CableTest-26-MAY-2023.x_t
(435.34 KiB) Downloaded 35 times
CableTest-26-MAY-2023.stp
(110.93 KiB) Downloaded 31 times
x 383
x 414
Re: Getting Path Centerline from imported surface
Yes, check this video
gt.adan
x 3
Unread post by gt.adan »
Here are the steps :
(1) Use the "Face Curves" function to create four mutually symmetrical curves. (Pic 1)
(2) Use the "Lofted Surface" function to generate two mutually perpendicular surfaces from these four curves. (Pic 2)
(3) The curve obtained by using the "Intersection Curve" function is the center line. (Pic 3 & 4)
