Design Table auto created only some of the configurations
jmongi
x 15
x 81
Unread post by jmongi »
So, I'm trying my hand at some design configurations. I created a design table, all the data is in there fine (this is for a compressed split lock washer). All of the # labels got created as a configuration (i.e. #2 size, #8 size, etc).
However, the fractional sizes did not get created (1/4, 5/16, 3/4, etc). Any thoughts? Is this a special character issue? I'm surprised "#" worked where "/" isn't.
Designated Pot-Stirrer
jmongi
x 15
x 81
Re: Design Table auto created only some of the configurations
Well, that was the answer. Changed "/" and they came in.
But...for some reason the whole numbers "1" and "2" got removed from the list? That one has me stumped.
To clarify, I had a list of sizes from 1/4 to 2. While the rogue character prevented SW from autogenerating configurations named that way, they still existed in the table itself. But, when I rebuilt all configurations, somehow the 1 and the 2 rows were just nuked from the table. I now realize (from recopying and pasting the original data) that it has done this before too. Any idea what is going on?
x 2191
x 1892
jmongi wrote: Wed Jul 19, 2023 4:05 pm Well, that was the answer. Changed "/" and they came in.
Maybe your configs are set in alphabetical order and that causes it to misplace it in comparison to your design table?
1 would be before 1/16 I believe in that case and 2 would be before 3/16"
I numbered them in decimal because I was running into something similar if I remember correctly.
Answers: 13
x 2050
x 1708
Random inexplicable problems in Solidworks? That's hard to believe.
XHawkeye
x 54
x 44
Unread post by XHawkeye »
Can't use '/' as a configuration name.
In our system, 95% of the time configuration name = our P/N so the '/' isn't missed. But when I've used fractions in configuration names, like Alex I've used decimals and then use the faction in the configuration description.
TTevolve
x 78
x 145
Unread post by TTevolve »
I purposely add a part number field to my design tables and don't use the configuration name as the part number for this reason. When you do BOM you can add a column for any property.
