File name of a part/assembly selected in a BOM
Rojnin
Unread post by Rojnin »
Hello,
Is it possible to get the file name of a part/assembly selected in a BOM?
I would like to run a macro when a line/case in a BOM is selected. This macro will change some custom properties of the selected file.
However, I can't find a source that tells me how to get the file name.
Thanks in advance.
x 7
x 822
Re: File name of a part/assembly selected in a BOM
TableAnnotation::GetCellRange() in conjunction with BOMTableAnnotation::GetComponents() will do the trick. Here's some sample code in C#:
ModelDoc2 mDoc = swApp.ActiveDoc as ModelDoc2;
SelectionMgr selMgr = mDoc.SelectionManager as SelectionMgr;
int type = selMgr.GetSelectedObjectType3(1, -1);
if (type != (int)swSelectType_e.swSelANNOTATIONTABLES)
	//No table selected
	return;
TableAnnotation tAnn = selMgr.GetSelectedObject6(1, -1) as TableAnnotation;
if (tAnn == null)
	//Something bad happened
	return;
if (tAnn.Type  != (int)swTableAnnotationType_e.swTableAnnotation_BillOfMaterials)
	//Not a BOM table
	return;
int firstRow = 0;
int lastRow = 0;
int firstColumn = 0;
int lastColumn = 0;
tAnn.GetCellRange(ref firstRow, ref lastRow, ref firstColumn, ref lastColumn);
if (firstRow == lastRow)
   //single row selected
   BomTableAnnotation bta = tAnn as BomTableAnnotation;
   object[] compObjArray = bta.GetComponents(firstRow) as object[];
   Component2 comp = compObjArray[0] as Component2;
   ModelDoc2 compDoc = comp.GetModelDoc2() as ModelDoc2;
   string compPath = compDoc.GetPathName();
Rojnin
Thanks JSculley,
I will try to use your code for my macro.
