Macro to change Drafting Standard for all drawings, then set all dimensions and tolerances to use document font
Library for macros
henry14286
Unread post by henry14286 »
Hello forumers,
I am working on a macro to:
1. Change Drafting Standard for all opened drawings in SolidWorks
2. Set all the dimensions and their tolerances to "Use document font" or "Use document size"
So far the macro is able to do the step 1, but I have no clue how to add the step 2 into the macro.
Can anybody help please?
Dim swApp As Object
Dim sDrawingCol As New Collection
Sub Main()
Set swDrawModel = swApp.GetFirstDocument
' Check to see if a drawing is loaded.
If swDrawModel Is Nothing Then
MsgBox "There is no active drawing document"
Exit Sub
Do While Not swDrawModel Is Nothing
If swDrawModel.GetType = swDocDRAWING Then
sDrawingCol.Add swDrawModel.GetPathName
Debug.Print swDrawModel.GetPathName
Set swDrawModel = swDrawModel.GetNext
Loop
If sDrawingCol.Count > 0 Then
FileSave = True
Else
Exit Sub
Set swDraw = swDrawModel
'Update Drafting Standard
Set Ext = swDraw.Extension
Ext.LoadDraftingStandard ("C:\Drafting Standards\ISO-Metric.sldstd")
' set all notes on this drawing sheet to the default font
SetAnnotationsToDefaultFont swDraw
Jump:
Loop
Set sDrawingCol = Nothing
Answers: 24
x 243
x 400
Re: Macro to change Drafting Standard for all drawings, then set all dimensions and tolerances to use document font
Here's a small example of how to do this using a snippet from a macro I wrote to do this with our specific templates. For each annotation, you can get the underlying object and cast it to the expected type. Then you can get the text format and then set it again with the second argument as "TRUE" which tells it to "Use Document Font".
Note, this probably won't run if you just plug it in to your code but should give you an idea on how this is used.
Dim allSheetViewArrays As Variant
Dim sheetViews As Variant
Dim formatIndex As Integer
allSheetViewArrays = swDraw.GetViews
Dim i As Integer
Dim j As Integer
For i = 0 To UBound(allSheetViewArrays)
    sheetViews = allSheetViewArrays(i)
    For j = 0 To UBound(sheetViews)
        Set swView = sheetViews(j)
        Set swAnno = swView.GetFirstAnnotation3
        swViewType = swView.Type
        While Not swAnno Is Nothing
            For formatIndex = 0 To swAnno.GetTextFormatCount
                If swAnno.GetType = swAnnotationType_e.swNote Then
                    Set swNote = swAnno.GetSpecificAnnotation
                    Set swTextFormat = swAnno.GetTextFormat(formatIndex)
                    swAnno.SetTextFormat formatIndex, True, swTextFormat
            Next formatIndex
            Set swAnno = swAnno.GetNext3
        Wend
        Set swView = swView.GetNextView
    Next j
Next i
