How to select coordinate system plane using API
Halasox
Unread post by Halasox »
I am trying to select a plane of a created coordinate system and then normal to it. It only works manually doing it, but not using API! o[
Appreciate any help!
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Coordinate System1\YZ Plane", "COORDSYS", 0, 0, 0, False, 0, Nothing, 0)
swApp.RunCommand swCommands_NormalTo, ""
Part.ClearSelection2 True
RonE
x 15
x 27
Re: How to select coordinate system plane using API
Unread post by RonE »
This seems to be a limitation. I also didn't find a way to select the COORDSYS planes or axes via API.
Answers: 13
x 2038
x 1701
My guess is that you are going to have to get more sophisticated and use the solidworks transform functions.
This might help you get the vector normal to the plane. (I'm not sure if the problem is with the selecting of the plane or the NormalTo command.)
https://help.solidworks.com/2017/englis ... ormal.html
