WasResolved from Get6 (CustomPropertyManager)
Posted: Fri Jan 26, 2024 4:32 am
by mihkov
How does Solidworks software decide which expression could be evaluated and which could not?
We are talking about the function Get6(Get5) of reading user properties through the CustomPropertyManager interface
value = instance.Get6(FieldName, UseCached, ValOut, ResolvedValOut, WasResolved, LinkToProperty)
value: swCustomInfoGetResult_ResolvedValue = 2 = (WasResolved=True) [Resolved value was returned]
I made the configuration from which I read the properties inactive and not rebuilt, and if UseCached = False the configuration is rebuilt and I get good mass values, and if True, then I get zeros in the calculated mass values. But "Was Resolved" always the True. How do you even get a False?
From general properties (not configuration)
Property: val1 / Value: "SW-Mass@Part.SLDPRT" / Resolved Value: 174.47 / Was Resolved: True
Property: val2 / Value: "SW-Mass" / Resolved Value: 174.47 / Was Resolved: True
Property: val3 / Value: "SW-Masss" / Resolved Value: "SW-Masss" / Was Resolved: True
Property: val4 / Value: "SW-Wasistdas" / Resolved Value: "SW-Wasistdas" / Was Resolved: True
Property: val5 / Value: "TT@mm" / Resolved Value: "TT@mm" / Was Resolved: True
Property: val6 / Value: "D567@Sk976" / Resolved Value: "D567@Sk976" / Was Resolved: True
From configuration properties
Configuration Property: val1c / Value: "SW-Mass@@ConfName@Part.SLDPRT" / Resolved Value: 174.47 / Was Resolved: True
Configuration Property: val2c / Value: "SW-Mass@Part.SLDPRT" / Resolved Value: 174.47 / Was Resolved: True
Configuration Property: val3c / Value: "SW-Mass" / Resolved Value: 174.47 / Was Resolved: True
Configuration Property: val4c / Value: "SW-Masss" / Resolved Value: "SW-Masss" / Was Resolved: True
Configuration Property: val5c / Value: "TT@mm" / Resolved Value: "TT@mm" / Was Resolved: True
Configuration Property: val6c / Value: "D567@Sk976" / Resolved Value: "D567@Sk976" / Was Resolved: True
Re: WasResolved from Get6 (CustomPropertyManager)
Posted: Fri Jan 26, 2024 8:28 am
by AlexB
The remarks section on the help page explain the scenarios where the resolved value can return false
https://help.solidworks.com/2018/englis ... ~get6.html
Posted: Tue Jan 30, 2024 9:57 am
by mihkov
AlexB wrote: Fri Jan 26, 2024 8:28 am The remarks section on the help page explain the scenarios where the resolved value can return false
I imitated these conditions and got WasResolved=True
Posted: Tue Jan 30, 2024 4:24 pm
by Stefan Sterk
I also tried to imitated these conditions, and also got only TRUE values for WasResolved, since the value cleary wasn't as is shown in the attached image below. Using SOLIDWORKS 2023.
Used the code below to create the resultes in immediate windows.
Option Explicit
Sub main()
    Dim swDoc As SldWorks.ModelDoc2
    Dim swPrpMgr As SldWorks.CustomPropertyManager
    Dim sPrpNames As Variant
    Dim sPrpName As Variant
    Set swDoc = swApp.ActiveDoc
    If swDoc Is Nothing Then End
    Set swPrpMgr = swDoc.Extension.CustomPropertyManager("")
    Debug.Print "Name Active Configuration: " & swDoc.GetActiveConfiguration().Name
    Debug.Print "## USE CACHED = TRUE ##"
    sPrpNames = swPrpMgr.GetNames
    For Each sPrpName In sPrpNames
        PrintPrps swDoc, CStr(sPrpName), True
    Next
    Debug.Print "## USE CACHED = FALSE ##"
        PrintPrps swDoc, CStr(sPrpName), False
    Next
Function PrintPrps(swDoc As SldWorks.ModelDoc2, sPrpName As String, Optional UseCached As Boolean = True)
    Debug.Print sPrpName
    ' General Property
    PrintPrp swPrpMgr, sPrpName, UseCached
    Dim sCfgNames As Variant
    Dim sCfgName As Variant
    ' Configuration Specific Property
    sCfgNames = swDoc.GetConfigurationNames
    For Each sCfgName In sCfgNames
        'Set swPrpMgr = swDoc.GetConfigurationByName(sCfgName).CustomPropertyManager
        Set swPrpMgr = swDoc.Extension.CustomPropertyManager(sCfgName)
    Next sCfgName
    Debug.Print ""
End Function
Function PrintPrp(swPrpMgr As SldWorks.CustomPropertyManager, sFieldName As String, Optional UseCached As Boolean = True)
    Dim ValOut As String
    Dim ResolvedValOut As String
    Dim WasResolved As Boolean
    Dim LinkToProperty As Boolean
    Dim lRet As Long
    lRet = swPrpMgr.Get6(sFieldName, UseCached, ValOut, ResolvedValOut, WasResolved, LinkToProperty)
    Select Case lRet
        Case 0 'swCustomInfoGetResult_CachedValue   0 = Cached value was returned
            Debug.Print "Cached   - " & WasResolved, ResolvedValOut, ValOut
        Case 1 'swCustomInfoGetResult_NotPresent    1 = Custom property does not exist
            Debug.Print "Missing  - " & WasResolved, ResolvedValOut, ValOut
        Case 2 'swCustomInfoGetResult_ResolvedValue 2 = Resolved value was returned
            Debug.Print "Resolved - " & WasResolved, ResolvedValOut, ValOut
    End Select
End Function
Posted: Tue Feb 06, 2024 8:23 am
by mihkov
Stefan Sterk wrote: Tue Jan 30, 2024 4:24 pm I also tried to imitated these conditions, and also got only TRUE values for WasResolved, since the value cleary wasn't as is shown in the attached image below. Using SOLIDWORKS 2023.
Well, what can I say: it was so, it is so, and it will be so forever and ever.
