Need to determine the value of DIM with attached GTOL
loeb
x 35
x 8
Unread post by loeb »
Given a selected GTOL frame, I need to determine the value of the DIM that the GTOL is attached to. It's easy enough to get the properties of a GTOL frame, and I can determine if it's attached to something, but getting the dimension itself is eluding me.
Thanks,
Answers: 11
x 19
x 452
Re: Need to determine the value of DIM with attached GTOL
Dim swDoc As SldWorks.ModelDoc2
Dim swAnn As SldWorks.Annotation
Dim vEnts As Variant
Dim swDisp As SldWorks.DisplayDimension
Dim swGtol As SldWorks.Gtol
    Set swDoc = swApp.ActiveDoc
    Set swGtol = swDoc.SelectionManager.GetSelectedObject6(1, -1)
    Set swAnn = swGtol.GetAnnotation
    vEnts = swAnn.GetAttachedEntities3
    Set swDisp = vEnts(0)
    Debug.Print swDisp.GetDimension2(0).Value
