[Code] vs [Quote] for code
For things you would put in a kitty dump.
x 599
Just curious, when it comes to API/macro/code, what do you prefer when you insert your code as answer/question in the forum?
Personally, I prefer to use quote just because i can do some text formatting to indicate some area that need to be change
'Lorem Ipsum
'Lorem Ipsum
'Lorem Ipsum
Code function has a select all option but cant apply any formatting
'Lorem Ipsum
[color=#FF0000]'Lorem Ipsum[/color]
'Lorem Ipsum
I rarely use upload unless it is a macro that i want to share as a whole.
x 7
x 822
Re: [Code] vs [Quote] for code
We need a proper syntax highlighter such as: https://www.phpbb.com/community/viewtopic.php?t=2557806. I'll request it in the Suggestions area.
x 1164
x 2296
JSculley wrote: Thu May 13, 2021 9:06 am We need a proper syntax highlighter such as: https://www.phpbb.com/community/viewtopic.php?t=2557806. I'll request it in the Suggestions area.
Ok, this is added, but I'm gonna rely on you guys to tell me if it's working or not. Here's a screen shot of the settings. Looks like they use some named themes. @JSculley if you have experience with this, do you want to suggest a theme to use?
x 7
x 822
Solarized. It's pretty popular. I use it everywhere I can. Let's give it a whirl:
public static void main(String[] args) {
	System.out.println("Hello World!");
int Main()
	Console.WriteLine("Hello World!");
The highlighting works well. It also gives you a 'Copy' button and a hint at what the language is. Nice.
x 1164
x 2296
JSculley wrote: Thu May 13, 2021 10:59 am Solarized. It's pretty popular. I use it everywhere I can. Let's give it a whirl:
Ok, I changed the theme to solarizedlight.
