Submit button takes me to preview
When replying to a topic, clicking the "submit" button takes me to the preview, where I have to hit submit again. I think that just started in the last day or two.
It happens when a reply came in between the time you pressed reply and the time you press submit. It's a simple warning to let you know someone replied before you, in case you were to repeat what the person said. You can see the reply above the preview
Go to full post-
- x 2191
- x 1891
Re: Submit button takes me to preview
That makes sense. Thanks.
Youch!, is this because of the style I'm using?AlexLachance wrote: ↑Thu Apr 08, 2021 9:39 am It happens when a reply came in between the time you pressed reply and the time you press submit. It's a simple warning to let you know someone replied before you, in case you were to repeat what the person said. You can see the reply above the preview
- x 1651
- x 2057
Probably. Here's what I see (I despise dark backgrounds).MJuric wrote: ↑Thu Apr 08, 2021 10:14 amYouch!, is this because of the style I'm using?AlexLachance wrote: ↑Thu Apr 08, 2021 9:39 am It happens when a reply came in between the time you pressed reply and the time you press submit. It's a simple warning to let you know someone replied before you, in case you were to repeat what the person said. You can see the reply above the preview
I will probably have to change styles because I can hardly see the sarcasm font color either.
- x 2191
- x 1891
That's gotta be one of those "side-effects" of having the ability of having light and dark mode on all skins, while having multiple other plugins.MJuric wrote: ↑Thu Apr 08, 2021 10:14 amYouch!, is this because of the style I'm using?AlexLachance wrote: ↑Thu Apr 08, 2021 9:39 am It happens when a reply came in between the time you pressed reply and the time you press submit. It's a simple warning to let you know someone replied before you, in case you were to repeat what the person said. You can see the reply above the preview
Well this style does not seem to be better in light mode...AlexLachance wrote: ↑Thu Apr 08, 2021 11:44 amThat's gotta be one of those "side-effects" of having the ability of having light and dark mode on all skins, while having multiple other plugins.MJuric wrote: ↑Thu Apr 08, 2021 10:14 amYouch!, is this because of the style I'm using?AlexLachance wrote: ↑Thu Apr 08, 2021 9:39 am It happens when a reply came in between the time you pressed reply and the time you press submit. It's a simple warning to let you know someone replied before you, in case you were to repeat what the person said. You can see the reply above the preview
- x 2487
- x 1888
How about if everybody just post in sarcasm?MJuric wrote: ↑Thu Apr 08, 2021 12:38 pmWell this style does not seem to be better in light mode...AlexLachance wrote: ↑Thu Apr 08, 2021 11:44 amThat's gotta be one of those "side-effects" of having the ability of having light and dark mode on all skins, while having multiple other plugins.
If a thread is very active, sometimes it is hard to hit the "submit" button fast enough
- x 2191
- x 1891
I'm sorry but,MJuric wrote: ↑Thu Apr 08, 2021 12:38 pmWell this style does not seem to be better in light mode...AlexLachance wrote: ↑Thu Apr 08, 2021 11:44 amThat's gotta be one of those "side-effects" of having the ability of having light and dark mode on all skins, while having multiple other plugins.
It's probably tweakable for each skin but there's a bunch right now and I'm guessing matt hasn't gotten around to all of them
