Four Tube Joint
Four Tube Joint
I saw a guy asking for advise about how to this on Reddit:
Anyway, I gave it a try using boundary stripes and fill surfaces, everything has a tangency continuity (Yey ):
But making all those Split Lines were a pain. Would be nice to have a subdivide tool on the edges, is there something like it?
One other way to split it would be with Trim Surface and add Split Entities on the sketch, but it does not feel appropriate to this 3D condition (I mean, having a good precision)
Please, share your thoughts and results!
This kind of joint is pretty common on carbon road bikes, although they are more likely to use truncated NACA profiles and probably an advanced surfacing software NX/Catia/Alias/whatever (do you know what they use? lol)Anyway, I gave it a try using boundary stripes and fill surfaces, everything has a tangency continuity (Yey ):
- Four-Tube Joint.SLDPRT
- (499.19 KiB) Downloaded 75 times
Re: Four Tube Joint
Not only that but I've never seen that specific joint on a bike. Looks like the head joint and fork...but that one would be really hard to turn withLucas wrote: ↑Fri Sep 24, 2021 2:21 am I saw a guy asking for advise about how to this on Reddit:
Re: Four Tube Joint
Well, bending a little bit and adding a hole you have the Bottom Bracket area, or adding another tube you have a model with integrated seat post. Not with this round shape tho, just steel bikes use them... but yeah, doesn't look so much, it just resembled me a Giant TCR SL for some reason. lol
Still, I tried to make a Bottom Bracket joint after this and failed miserably. Doing something like a carbon frame modeling in SW seems a work for masochists hahaha
Re: Four Tube Joint
I'm not a surface guy but I suspect that the "Best" and possibly only way to get a good carbon fiber model for something like that is with surfaces.Lucas wrote: ↑Fri Sep 24, 2021 11:45 am Well, bending a little bit and adding a hole you have the Bottom Bracket area, or adding another tube you have a model with integrated seat post. Not with this round shape tho, just steel bikes use them... but yeah, doesn't look so much, it just resembled me a Giant TCR SL for some reason. lol
That's a case where something with more organic capabilities would be the better choice over something like SW.
Re: Four Tube Joint
If you don't like using the split points in the trim sketch, you could just use the handles in the feature. Maybe constrain them to 3d sketch points. I don't know of any way to split edges directly. I've made several joints like this, and have always used the split points in trim curves.
- bikeex1104.tif (115.2 KiB) Viewed 2666 times
Re: Four Tube Joint
That's some nice joints. Have you tried making some in SE?matt wrote: ↑Fri Sep 24, 2021 12:48 pm If you don't like using the split points in the trim sketch, you could just use the handles in the feature. Maybe constrain them to 3d sketch points. I don't know of any way to split edges directly. I've made several joints like this, and have always used the split points in trim curves.
Using Subdivision looks so nice and smooth, can't wait to have this in SW lol
- zxys001
- x 2269
- x 972
Re: Four Tube Joint
It's very possible in SW... but yeah, it takes time setting up.... and yeah, it would have been friggin great if DS would have had the balls to include SubD into SW but they failed all of us.Lucas wrote: ↑Fri Sep 24, 2021 2:21 am I saw a guy asking for advise about how to this on Reddit:
One of the kewlist new features in Rhino3D is MultiPipe.. it's exactly what your wanting... I did this in less than a minute in Rhino and ~3min total to transfer into SW. (images)
..oh,.. an attempt of your blend in SW.
- Four-Tube Jnt-z.zip
- (874.04 KiB) Downloaded 65 times
- x 1232
Re: Four Tube Joint
FWIW, we all know that DSS could add it to SWX desktop since they added it to 3DX.
https://www.goengineer.com/solidworks-2 ... nphapcpsoz"
The alternative is Solid Edge. They added Sub-D in 2019 [edit: 2021, actually] and are expanding it.
- x 2172
- x 1859
Re: Four Tube Joint
@Alin Next SWPUC?
Edit: now that I think of it I believe you've already done a SWPUC along that line.
- x 2487
- x 1888
Re: Four Tube Joint
Pfft...if he hasn't there's no need, I'd win (and I didn't need any fancy software to solve this problem):AlexLachance wrote: ↑Mon Sep 27, 2021 11:52 am @Alin Next SWPUC?
- x 1232
Re: Four Tube Joint
I don't see anything wrong with that.mattpeneguy wrote: ↑Mon Sep 27, 2021 2:38 pm Pfft...if he hasn't there's no need, I'd win (and I didn't need any fancy software to solve this problem):
Isometric view is correct.....
Speling is corect....
All caps for notes.....
Re: Four Tube Joint
This is a whole different level of modeling. Please, show me the waymattpeneguy wrote: ↑Mon Sep 27, 2021 2:38 pm Pfft...if he hasn't there's no need, I'd win (and I didn't need any fancy software to solve this problem):
- zxys001
- x 2269
- x 972
Re: Four Tube Joint
..that font should be in cursive if you want G2 or G3.mattpeneguy wrote: ↑Mon Sep 27, 2021 2:38 pm Pfft...if he hasn't there's no need, I'd win (and I didn't need any fancy software to solve this problem):
Re: Four Tube Joint
Although it's only 2 pipe & 3 pipe examples, there's a how-to lesson at MySolidWorks>Training:
https://my.solidworks.com/training/mast ... lex-blends
- x 7
- x 16
Re: Four Tube Joint
Fanstastic outcome there.
Do you ever do your surfacing in Rhino and then bring that surface into SolidWorks to finish off the part?
I've been considering this as a workflow to get better surfacing designs done.
- zxys001
- x 2269
- x 972
Re: Four Tube Joint
Not often enough. I just add what I need when I need it when SW can't and go back to SW.Cbecks Design wrote: ↑Tue Aug 09, 2022 5:10 pm Fanstastic outcome there.
There are many ID Designers/Companies I've worked which use Rhino3D, very common.
It's worth getting or look at Moi3D.
Re: Four Tube Joint
I posted about this plug in for Solidworks but if this is the kind of work you do, and lord knows NO new surfacing tools have been introduced in over 10 years, then you might want to take a look at X-Nurbs.
As far as SubD modeling goes (and this is staying within the more CAD-Like Software's)
- Modo
- Rhino3D
- MOI
- Fusion 360
- SolidEdge
- xDesign
- Modo
- Rhino3D
- MOI
- Fusion 360
- SolidEdge
- xDesign
- Krzysztof Szpakowski
- x 58
- x 75
Re: Four Tube Joint
Your example is so simple that it can be done without using surface tools. We often complicate the task ourselves. Sometimes it's better to send a soldier on a bicycle with grenades than to send tanks ;-)
