Running a VB script inside solidworks macro?
ResidentAtLarge
x 30
Unread post by ResidentAtLarge »
Is there a command in solidworks macro to run a VB script and then place a pause for 1 second while it runs? I am not finding any information on how to do this anywhere.
x 2487
x 1888
Re: Running a VB script inside solidworks macro?
This can get you a Sleep for 1 second:
Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Dim swApp As Object
Sleep (1000)
Also, isn't VBScript a subset of VB? Could you just copy the code into the macro?
ResidentAtLarge
x 30
mattpeneguy wrote: Tue Nov 02, 2021 11:11 am Also, isn't VBScript a subset of VB? Could you just copy the code into the macro?
I wasn't sure if vb could be run directly inside of solidworks VBA or not. I am not someone who knows a whole lot about programming either.
Thank you for the delay code!
Answers: 24
x 243
x 400
We've used this to run a compiled external program.
    Shell ("C:\PathToYourEXEFile\SolidworksScript.exe")
x 2487
x 1888
AlexB wrote: Tue Nov 02, 2021 11:50 am We've used this to run a compiled external program.
Unfortunately that won't work for a vbs script... You need access to the WSH, I think. Someone like @josh or @gupta9665 would probably be able to answer this. I think it's possible it's not allowed because of security.
RMcHugh
x 82
x 29
Unread post by RMcHugh »
I remembered reading a similar question a while back. Didn't realize how long ago...
I found this in the SWYMp: https://r1132100503382-eu1-3dswym.3dexp ... MACNSJXzOg
TL/DR: Use RunMacro2 method, answered by @gupta9665
Disclaimer: I have no actual experience with the command, just a fuzzy, semi-functioning memory system.
Hope this helps,
Ray
x 7
x 822
ResidentAtLarge wrote: Tue Nov 02, 2021 9:53 am Is there a command in solidworks macro to run a VB script and then place a pause for 1 second while it runs? I am not finding any information on how to do this anywhere.
Are you wanting to run a visual basic program or a VBScript script? They are two different things.
ResidentAtLarge
x 30
JSculley wrote: Tue Nov 02, 2021 1:49 pm Are you wanting to run a visual basic program or a VBScript script? They are two different things.
I am looking to run a VBScript Script file.
x 2487
x 1888
RMcHugh wrote: Tue Nov 02, 2021 1:28 pm I remembered reading a similar question a while back. Didn't realize how long ago...
Hope this helps,
Ray
@RMcHugh,
It appears that will only run a Solidworks SWP macro, not a vbs script.
ResidentAtLarge
x 30
My VBScript code I am looking to use is below:
Const ForReading = 1
Dim arrLine()
Dim lnCnt
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objTextFile = objFSO.OpenTextFile("c:\temp\BOMTable_Export_TESTING.SLDASM.txt", ForReading)
'Read the csv file to get the header column names and data for each row.
Do Until objTextFile.AtEndOfStream
	strNextLine = objTextFile.Readline
	lnCnt = lnCnt + 1
	If lnCnt = 2 Then
		arrHeaders = Split(strNextLine, vbTab)
	If lnCnt > 2 Then
		Redim Preserve arrLine(lnCnt - 2)
		arrLine(lnCnt - 2) = strNextLine
Loop
objTextFile.Close
'Load the data into a multidimentional array.
ReDim arrData(UBound(arrLine), UBound(arrHeaders))
For i = 0 to Ubound(arrLine)
	line = Split(arrLine(i), vbTab)
	For p = 0 to UBound(line)
		arrData(i, p) = line(p)
	Next
Next
'Find operations notes and raw material.
ReDim arrOperations(0)
ReDim tmpMaterial(0)
ReDim tmpMatIdx(0)
ReDim tmpMatQty(0)
For i = 0 to UBound(arrData, 1)
	curOper = arrData(i, GetColumnIndex("RawOperation"))
	If curOper <> "" Then
		idx = -1
		For o = 0 to UBound(arrOperations)
			If InStr(1, arrOperations(o), curOper) = 1 Then
				idx = o
				Exit For
		Next
		If idx = -1 Then
			Redim Preserve arrOperations(UBound(arrOperations) + 1)
			Redim Preserve arrRawMaterial(UBound(arrRawMaterial) + 1)
			idx = UBound(arrOperations)
			'Begin operation notes.
			arrOperations(idx) = curOper
			If arrData(i, GetColumnIndex("RawNote1")) <> "" Then arrOperations(idx) = arrOperations(idx) & vbCrlf & arrData(i, GetColumnIndex("RawNote1"))
			If arrData(i, GetColumnIndex("RawNote2")) <> "" Then
				arrOperations(idx) = arrOperations(idx) & vbCrlf & arrData(i, GetColumnIndex("RawNote2"))
				qty = arrData(i, GetColumnIndex("<FONT size=57PTS>QTY."))
				If qty > 1 Then arrOperations(idx) = arrOperations(idx) & vbCrlf & "(" & qty & " PER UNIT)"
			'Begin raw material
			mat = arrData(i, GetColumnIndex("RawPartNo"))
			If mat <> "" Then
				matIdx = -1
				For m = 0 to UBound(tmpMaterial)
					If mat = tmpMaterial(m) Then
						matIdx = m
						Exit For
				Next
				If matIdx = -1 Then
					Redim Preserve tmpMaterial(UBound(tmpMaterial) + 1)
					Redim Preserve tmpMatIdx(UBound(tmpMatIdx) + 1)
					Redim Preserve tmpMatQty(UBound(tmpMatQty) + 1)
					matIdx = UBound(tmpMaterial)
					tmpMaterial(matIdx) = mat
					tmpMatIdx(matIdx) = idx
					tmpMatQty(matIdx) = CDbl(arrData(i, GetColumnIndex("RawMaterialQty")))
				Else
					tmpMatQty(matIdx) = CDbl(tmpMatQty(matIdx)) + CDbl(arrData(i, GetColumnIndex("RawMaterialQty")))
		Else
			'Add operation notes.
			If arrData(i, GetColumnIndex("RawNote1")) <> "" Then arrOperations(idx) = arrOperations(idx) & vbCrlf & vbCrlf & arrData(i, GetColumnIndex("RawNote1"))
			'Add raw material
			If mat <> "" Then
				matIdx = -1
						matIdx = m
						Exit For
				Next
				If matIdx = -1 Then
				Else
Next
'Display output
Set outFile = objFSO.CreateTextFile("c:\temp\operationnotes.csv", True)
Dim oLine
For i = 0 to UBound(arrOperations)
	oLine = chr(34) & Replace(arrOperations(i), chr(34), chr(34) & chr(34)) & chr(34)
	For m = 0 to UBound(tmpMatIdx)
		If tmpMatIdx(m) = i Then
			oLine = oLine & ", " & tmpMaterial(m) & ", " & tmpMatQty(m)
	Next
	outFile.WriteLine(oLine)
	'Wscript.Echo arrOperations(i) & vbCrlf & vbCrlf
Next
outFile.Close
'Returns the index number of the column name passed.
Function GetColumnIndex(columnName)
	GetColumnIndex = 0
	For c = 0 to UBound(arrHeaders)
		If arrHeaders(c) = columnName Then
			GetColumnIndex = c
			Exit For
	Next
End Function
x 2487
x 1888
@ResidentAtLarge,
I'm not sure if it'll run from within a SW macro. I thought the "Scripting.FileSystemObject" wouldn't work, but it may according to this:
https://help.solidworks.com/2019/Englis ... nction.htm.
If you can setup a sandbox, to make sure you don't mess any production data up, you could try running it and see what happens. I was hoping Josh or Deepak would've replied by now. I'm sure they can conclusively say whether what you want to do is possible and if so how best to do it.
ResidentAtLarge
x 30
mattpeneguy wrote: Tue Nov 02, 2021 4:01 pm @ResidentAtLarge,
I will wait and see what Josh or Deepak say.
