Global Variables / System Values Decimal Places
Rob
x 788
x 207
Unread post by Rob »
Hey up
This has kept me 'entertained' for the last few hours.
I have some code that checks the value of a global variable against a dimension value.
The idea is that I only update the global variable if it is different.
If there are no changes then I do not save the part.
Despite initially working something changed and whatever happened my part kept saving. It had me scratching my head.
Only when I looked at all the decimal places did it dawn on me what was happening.
Now that I know the problem - I'm still not sure how to solve it.
I could check the value of the equation instead of the value, or perform rounding myself.
I guess whatever you put in 8 d.p. is the maximum you can get back from a global variable but the system value of the dimension is 13 d.p after I'd converted to mm. My naïve conversion to a string gave me 11 d.p.
Tricky stuff this programming lark.
Rob
x 788
x 207
Re: Global Variables / System Values Decimal Places
I thinks I've solved it (well stack overflow did)
