i am trying to do mates in assembly , during that i am facing error in mates , how to resolve this
Thank you
cylinders are not parallel
- x 1232
Re: cylinders are not parallel
Can you upload your file? My crystal ball is dusty today.
THANK YOU for reply , i did again mates , but problem facing the assembly is fully defined cant move , please see the file
the linkage should move by hydraulics
thank you
thank you
- P10.rar
- (502.06 KiB) Downloaded 35 times
- x 3
- x 5
The problem lies in your sketches for the base. They should be fully constraind, there are lines not parallel which should be.
Edit: Just checked the other parts, same problem there. Try going through a couple of tutorials - at least the basic ones. It will help you at lot.
Thank you very much yes I edit base and other parts , perfectly moving
