Form tool Not In Design Library, Except It Is
Granet
Unread post by Granet »
Hi
I'm trying to form sheet metal and have saved the form tool to the Design Library -> Forming Tools -> Embosses file, as you can see in the lower right folder.
However when I try to open it in the Design Library to drag it into the part file, it's not there, there's also no Forming Tools folder or Embosses folder.
I've tried adding the forming tool using the +books icon under the Design Library heading, but no luck.
Any suggestions?
Thank you!
