I had been trying to insert a BOM in assembly but the formatting (TEXT FONT) seem to keep running (not following template)...
The header font was set to 8pt in the template but after insert at scale=1.0, it still run to font 11pt...
BOM insert in assembly (INCORRECT FORMATTING, TEXT too big at scale = 1.0)
BOM insert in drawing via INSERT BOM (CORRECT FORMATTING)
Even though i had tried adjust the formatting again, but when the BOM is "COPIED" to a drawing (via copy existing table), the formatting run again...
BOM insert in drawing via COPY EXISTING TABLE after re-adjust formatting in ASM
Anyone had any idea why this happen and how to solve it?
BOM (in asm) not following formatting/template
After some debugging and trial and error,
it seem that using [pt] for the font is a bad idea, changing the font to mm seem to solve the issue.
Go to full postit seem that using [pt] for the font is a bad idea, changing the font to mm seem to solve the issue.
Re: BOM (in asm) not following formatting/template
After searching around, it seem that the formatting is not linked...
But i am still wondering what formatting did SOLIDWORKS used when copy the BOM as it does not seem to be using document formatting settingFar too many items in the world are designed, constructed and foisted upon us with no understanding-or even care-for how we will use them.
